Yeah. But the DI-20HE with the new HDMI 2021 boards in the dac will for sure win over everything else; so may be more complex- but still is going to have better results.
This is correct, but here in details. Over the I2S interface DI-20 provides clock to the R-7HE. It is a master clock for DA conversion, so quality of the sound depends on the clock quality of DI-20. It is not better than the internal clock of R-7HE, as HE means regenerative power supply, DI-20 do not have. It means in general that if you want to improve sound of R-7HE over I2S, your source must provide more clean clock than R-7HE creates internally.One thing doesn't make sense to me:
If the DI has the 2021 usb module then why does the R-7HE 2021 sound better with direct usb conection than using the DI-20?
The only answer I can think of is that the DI-20 non HE model pollutes the sound more than the advantage that I2s via the DI-20 provides and results in a net loss.
I understand correctly that those who bought THE r7he 2020 remain on the sidelines? Or is it still possible to upgrade at least the HDMI input to improve performance in conjunction with DI20HE?http://www.audio-gd.com/R2R/2021upgrade/2021upgradeEN.htm
R-7,R-7HE: Impossible upgrade by self.
Same here. A greater factor is the fact that the di20he is better isolated electrically and cannot contaminate the dac, especially now with the new i2s isolator. Without it, the new internal usb would possibly win.One thing doesn't make sense to me:
We'll know soon.
In fact, it's no, not an easy upfrade for the r7/he, i just caught up.We'll know soon.
I asked this question... I hope he answers it.Good questions for Kingwa.
Kingwa: If you want only upgrade the HDMI with isolator, that is easy, you even don't want update the firmware, just replace the HDMI module to the new one.
Connect the HDMI module to the Amanero power, it is isolative power, the isolator of the HDMI input is use the on board power.
Good choice!I have ordered the R8HE 2021...
Are the upgrade instructions on the audio-gd website with all those pictures what need to be done for the HDMI and USB 2021 upgrade?
I only want to do the HDMI upgrade and I ordered the 2021 board. In the pictures it looks like the HDMI is connected to the usb board.
Just seems 2021 internal USB is the cleaner/ less complicated path by a significant margin.
..With the DI20HE (3.933) the sound gets more flesh, a little higher temperature and more life...Yeah. But the DI-20HE with the new HDMI 2021 boards in the dac will for sure win over everything else; so may be more complex- but still is going to have better results.
