FredA
- Dec 15, 2013
The new DI is up for sale in regen and regular version. I already requested a quote.
http://www.audio-gd.com/En audio-gd.htm
Same here. Too punchy for my tastes. But with the new DI, i might prefer the latest.took a while for me to test the R7 2020 firmware vs the P2-dsdclck version
I like the bass and attack of the 2020 firmware on my 2019 R7HE, but the treble is too hot on what should be a warm-leaning listening set up (Glenn OTL amp with Mullard ECC32 driver, GEC 6AS7G power tubes and ZMF Verite).
Back to dsdclck version for me for now @FredA @JaMo
If enough people ask for it, Kingwa might add it to the regular version. It sure looks more high-end with it.As for the hotness of the new firmware, I suspect it's Kingwa's attempt to compensate for his room. I've seen the FR plots of his room and there is a treble roll off. Manufacturer recommendations for his speakers is 5 degrees of axis for flat response but Kingwa likes to place his speakers so they fire down his room in a straight line, hence the treble roll off.
Yes. All of them are great values IMO as always with Kingwa's gears. I really like how Kingwa laid out the pci. Seems very optimal.DI-20 Pricing is on the Audio GD website -
DI-20 with TXCO - USD449
DI-20 with Accusilicon 45/49M - USD499
DI-20 with Accusilicon 90/98M - USD549
DI-20HE with Accusilicon 90/98M - USD988
Pretty good value when you compare to a Singxer SU6 at USD621
You get lower jitter with the 90/98. They just cost more to purchase. But if you use an external clock, it does not matter. The internal ones have no impact on sound quality then.About the new DI2020, in what case would one go for the "Accusilicon 90/98M Edition" instead of the "Accusilicon 45/49M Edition"?
I read Kingwa's description but I'm a simpleton and it's slightly over-my-head.
[...] but Kingwa likes to place his speakers so they fire down his room in a straight line, hence the treble roll off.
So in my case I would be connecting my Mac to the DI-20 via USB, then i2s to my R1.You get lower jitter with the 90/98. They just cost more to purchase. But if you use an external clock, it does not matter. The internal ones have no impact on sound quality then.
The external clock is an external unit from other vendors, there are many possibilities for all budgets. It is a path to a future upgrade. And i will test both the external one i have and the internal when i get my unit.So in my case I would be connecting my Mac to the DI-20 via USB, then i2s to my R1.
No external clock in that chain, correct?
You bet i am.Funny, that's how I have my speakers set up (save for a couple of degrees of toe-in).
Are you getting the HE/regen version? Either way, I'm looking forward to your impressions.
