BreadMaster
- Apr 23, 2019
So what's the best $10k dac these days? Please don't say Dave.. -_-
What about TotalDAC D1 CORE? $4700 eurosR7HE obviously.
But if R2R isn't the sound you're after, I think the EAR Yoshino DAC 4 is better than the Chord Dave, and it's cheaper too.
Seems like a valid contender. Reading the review, the listening impressions ressemble mine with the R7-HE.What about TotalDAC D1 CORE? $4700 euros
A faithful source will reproduce distorsion faithfully. Also, you amp must be able to receive the signal level the r7 outputs.. If just on certain recordings, it is most likely on the recordings themselves. Could also be a problem with your amp. I have no such issue.Has anyone experienced any issue with their DAC's XLR balanced output? I am beginning to wonder of one of my output is causing some distortions since when I switched back to RCA unbalanced that distortion is reduced or gone. Now I have tried another DAC with balanced output and the distortion is much less (more tolerable), I am not sure if it is too revealing or some defect but at times it seems to be definitely abnormal distortion or clipping-like sounds. I think it is only on 1 channel.
I have tried a different DAC with balanced outout and issue seems less obvious or gone, and i Can't figure out if this more of a recording issue or not. Happens even on some really good recordings, if more rare.A faithful source will reproduce distorsion faithfully. Also, you amp must be able to receive the signal level the r7 outputs.. If just on certain recordings, it is most likely on the recordings themselves. Could also be a problem with your amp. I have no such issue.
Most album have at least a few defects. The most common derect is going beyond the recording max admissible level and will cause distorsion. The old jazz albums are full of this. This becomes really obvious with planar headphones.I have tried a different DAC with balanced outout and issue seems less obvious or gone, and i Can't figure out if this more of a recording issue or not. Happens even on some really good recordings, if more rare.
Does anyone know if the PLL mode applies for all digital inputs or just the USB ??
Thanks!
