Might be hard to describe the difference if he did the Amanero and EFI at the same time. Hopefully he didn't, so he can speak to how each mod sounded individually.
Stillhart
I was careful about testing these with each upgrade as a separate step.
I installed the Amanero and tested for about 2 hours with music i'm familiar with. This was with my Master11 BTW. I noticed the increased separation and soundstage further improved or changed slightly. The smoothness of the sound seemed slight too. I had an issue though, I lost about 6db in the right channel for some reason. I did a power cycle and it fixed the problem. I emailed Kingwa about it and he asked me to double check my soldering job and the connections in general. Also commented its possibly a cable. He asked me to take a photo of the work I did to verify. I did, so I opened up the M11 again to take a photo and verify. It was at this time I decided to install the 3M EMI/RF material since i've opened it up again.
I took photos for Kingwa, and he said everything looks good. I have not had a problem since with the right channel being 6db quieter. (approx)
I installed all the 3M absorbtion film on the DAC for the first attempt. ALL PCM1704UK's were covered, and the DSP chip. I tested it at that point and wasn't sure if I heard any difference or not. If so, it was very slight. I'm talking about slight because the M11 sounds so damn good already! not too much to improve or change. I opened it back up and added it to the two chips on the Amanero and left the clocks uncovered. I also added large pieces to the portion that is directly above the DAC PCB. 3 large rectangles as seen in the photo. The aluminum walls clear the edges of the absortion film just slightly by 1mm. Further shielding the already perfectly shielded M11.
(I may add more to some of the IC's that are still exposed, I covered more on the NFB28 than the M11)
If anything was improved, it was subtle. The difference to the NFB28 was more significant. I swear it was due to the less than ideal shielding. The 2015 does have much better shielding than the 2014 model. Yet, the shielding doens't go all the way up to the top panel like the M11. It has at least 1/2 gap. I put shielding over the transformer, as well as the sabre chip and many other small IC's. Will load photos of the NFB28 2015 edition later.
I think it smoothed out the sound a little more. I also did this in steps from Amanero first....testing...AOK... add absortion film....test. AOK.
I don't think the absortion film was worth it on the M11. but will test more. I just didn't notice as much. I'm pretty sure it helped the NFB28 though. It sounds incredible now! It was a good upgrade just going to the amanero with the NFB28! but the combo made it sound so smooth and glare is gone. Sound is so smooth and unlike sabre sound. The details are still there!
Would I do it again to future Dacs? sure! I figure with a comibination of many upgrades/mods that you will likely get small changes that will add up overall to maybe 1,2,3% in the end. Each change could be .5% or inaudible for most cases. But this is just my theory. I love to tweak things.
I modded both of the Schiit Wyrd's I have for each dac. They also had the absorbtion film added to the USB boxes, and all the IC's/clocks etc. But I have been thinking of removing the Wyrd since it's clock is rated for 200picoseconds and the Amanero is at 0.04-2.42picoseconds. I don't know if it will do anything now. Thats my next test. taking it out of the loop so to speak.
The Elfidelity USB has been a nice upgrade, as it's running with the Teradak U9 Linear power supply. Sure, Audio-gd doesn't use power in the USB cable. But keeping the power clean in the cable may possibly keep interference in the cable to a minimum. and it isolates the USB port inside the computer from all the noise It can pick up if it was plugged into the PC's powersupply or power from the motherboard.
