I actually was considering a THX AAA 789, but I was also considering a Fiio A5 just so I don't spend too much. Is the power output the only thing that matters in an amp or are there other factors? For example, a $100 amp outputs more than a $500 but the $500 sounds better in every other regard? The A5's can drive the HD800s and Auras properly, but I feel like it will make my setup sound noisy and like a $100 setup and render my DAC's conversion useless. To put it another way: would connecting a Chord Qutest to a $100 amp make the setup sound like a cheap $100 setup too? How much does the amp affect the sound quality? What's the difference between a cheap and expensive amp? Is the only difference power output and output noise (the A5 has very low noise and pretty powerful)? Are all amps the same?
Yeah but my DAC/AMP is the same price as the mojo and iDSD BL, so the DAC part is great. I don't need a dac, just an amp. How do I try before I buy? I've never done that.
They look nice, but I heard the Auteurs are a bit warm. I'm looking for more reviews for the Clears.
IDK, but if they're more expensive that means they have better quality sound components? If a $2000 amp is not better than a $100 amp why would it be more expensive?
Sometimes I just wish to get a Hugo with focal utopias and get it over with. One can only dream...
I have a 4k amp and a 200 Amp. The difference is minor when comparing headphones that can easily be driven. In some aspects like sensitive IEMs the 200 Amp is even better. I heard 500 € and 1000 € Amps before that were worse than the 200 € amp.
Like i said the best headphone i have today is a HD600 for 300 €. I have 1500 € headphones here that are outperformed by my 100 € AKG 702.
Price means nothing in terms of soundquality in this field.
You ask why a 2k amp is more expensive than a 200 € amp then?
There are two possibilities
A) it offers more versatility like in my case a lot more power, tubes, ability to drive stax, xlr etc.
B) it's basically the same like the 200 € amp. People like you who only look at the price think it has to be better and buy a 200 € amp for 2000 €.
