Mike F
- Dec 11, 2009
I think that’s exactly what it does, presumably so that if you have a device which only has the 4.4 balanced output you can still use a single ended cable was it.It seems like what this does is "downgrade" your balanced amp signal to SE so it works with a SE headphone. Whatever advantage the balanced output offered would be lost in that case.
