I've been searching all over the internet to find someone that has done this but keep coming up empty handed. I finally took a stab at it. IMO these are criminally underrated cans, but I HATE the cable nightmares they come with, and they really deserve to be able to run from a proper balanced 4 pin desktop amp. It has always bugged me that studio cans don't have the option of consuming independent signals (thank goodness the DT1770 Pro's come with a mini XLR from the factory!)
So, here it is - the Neumann NDH-20 Balanced studio monitor headphone , with Mini 4pin XLR and 4.4mm PentaConn . They of course can also be driven SE via the correct cable. Please forgive if this is not the right place to post. As you can see I've been a lurker for... a bit.
This job was a *hell* of a trick. I had to take a bunch of measurements, then mock the cup and the jack in 3d software, then design 2 custom angled and curved bushings to ensure the jack was perfectly aligned. Then I had to disassemble the cups to see if I could shoehorn them in. Is it getting hot in here?
There is about 1mm of clearance in jack placement within the cup itself, and about .5mm in clearance for the jack's panel lip. The tolerances on this job make positioning this jack incredibly difficult. 3 different jigs were designed and tested to properly place and cut the hole to spec before finding the courage to start grinding.
Additionally there are a few other challenges,. Besides removing some internal jack-boss structure of the cup, the right side also needs to be ported in the same manner as the left (right side is ported via its minijack port in stock config, left side has a ~2mm^2 port). The internal minijack PCB gets pulled in favor of direct-solder to the 4 pin.. A spot of damping needs to be added back to one spot where a small block of boss structure is removed. It took a lot of time to remove the material without causing a lot of damage.
There is also some boss structure that is part of the driver panel, which also needs to be removed and then sealed (the 9 foot long minijack reinforcement).
I've done a few of these (I own multiple sets of balanced modded NDH-20) and wanted to share here since I cannot find a single other person who has done this mod.
I do plan on modding a set of 30's once I have a set in hand, but I need to make room for those
I'd be happy to post that mod job here if people are interested. I know they use the same material in those cables, which I think is some sort of spring steel.
Cheers!
