Aug 30, 2010 at 2:41 PM Post #2 of 6
well i have only heard comparisons to the dba vs westone 2 and most like the dba better so I would assume the dba are superior to the 1. Some prefer the dba to even the westone 3
Aug 30, 2010 at 3:23 PM Post #4 of 6
^ lol.
The Westone 1 does a few things well but it has trouble covering the entire frequency range with its single armature. The top end especially sounds somewhat strained and de-emphasized. The DBA-02 has excellent presence throughout and also sounds cleaner/clearer than the W1. I could go on and on but in short, the DBA-02 is by far the better earphone as far as I'm concerned.
Aug 31, 2010 at 11:58 AM Post #5 of 6
thx for the info.
how are the ear tips for the dba 02? i know that the westone comes with many tips including the foam tips. but the dba 02 only has the normal tips. are they comfortable? and do they have a good seal?
Aug 31, 2010 at 4:10 PM Post #6 of 6
well the new batch has new tips, so I havent really heard much about them- they seem fine. But if they dont work you could always get some sure or etymotic tips
