Skampmeister
- Oct 7, 2015
I bought a new DAC+ and the new Chord Qutest this week. In the process of comparing the two.
But there is an issue with the DAC+ volume attenuation jumpers. Mine was running a tad hot into my pre, so off the lid went to insert the 4 jumpers.
Left channel was fine, but the right channel has major issues, frequent ticking noise with the sound dipping with each tick, very quickly.
Tried it a few times, but no change, thought I might have a bad unit, so I emailed Mytek and got a swift 5 minute reply informing me that they found a bug, and the jumpers must be removed, and next week they will be releasing a firmware update that’ll add a gain control for each input on the control panel, the same way it’s done on the Manhattan II.
