MYSPHERE 3.1-UNIQUE in SOUND&DESIGN&BUILD QUALITY
Jul 20, 2019 at 1:00 PM Post #1,022 of 1,535
Hi,
MYSPHERE will show the product in room Plaza Suite 11 partnering with Woo-Audio.
You can compare on following amps:
WA8; WA7; WA33; 3ES; WA11 following headphones:
STAX SR-009S; MYSPHERE 3; ABYSS 1266 Phi; Diana Phi; Meze Empyrean; Sony IER-Z1r
Guess which one will win!? :wink: :jecklinsmile:
BR heinz
Jul 21, 2019 at 1:47 AM Post #1,023 of 1,535
Hi,
BR heinz
Hello Heinz,
Really should be comparing the new Abyss TC instead of the Phi there is a surprisingly large difference. Must get myself a pair of the MYSphere's though!
Jul 21, 2019 at 2:49 PM Post #1,024 of 1,535
Hello Heinz,
To clarify, 1266 Phi is no longer produced1266 Phi is no longer produced. We will have the latest 1266 TC and Diana Phi.
Jul 22, 2019 at 1:43 PM Post #1,025 of 1,535
With CanJam just around the corner I'll get to hear the best headphones I've ever listened to again. Can't wait to see what this SR1a business is all about but somehow I don't feel it will win me over.
IMO the Mysphere and the SR1a's are complimentary. An excellent and midrange-focused can with great fault tolerance for recordings, and a perfectly neutral one with zero tolerance.
Jul 23, 2019 at 3:16 AM Post #1,027 of 1,535
Which MyShpere? 3.2 maybe if driven properly with an aftermarket cable, 3.1 never. The HD650 is an excellent midrange-focused can, on par with 3.2 on the same setup for 5% of the cost.
Jul 24, 2019 at 1:11 PM Post #1,029 of 1,535
Which setup are you referring to?
I haven't heard any Mysphere-optimized setup where the HD650 is on par in any way with the Mysphere 3.2. The 3.2 is poor on non OTL-tubes but that's a separate discussion.
Jul 24, 2019 at 1:39 PM Post #1,030 of 1,535
WA5 with Elrog 300B, 422A and ECC32 using the high impedance tap. My guess is 3.2 works best on OTP with a high 120ohm option or speaker amps. 3.2 on OTL does not work, if it distorted like crazy on the BH Crack and Apex Teton I don't know what OTL can drive it with bass focused music. WA5 was a dream to listen to.
A very modified HD600 with HD650 drivers has the mid range withing a few percent of the 3.2 on the WA5, overall 3.2 is still better yes for 20x the price.
If I were to get just one it'll have to be 3.1, many mid range cans on the market, K1000 has better soundstage and close mid performance but nothing can touch the transient response on 3.1 with a 5K+ setup.
Jul 26, 2019 at 7:36 AM Post #1,031 of 1,535
Is the warranty really one year for these? All other flagships are 3 years and up.
Any warranty only covers deficiencies, to the extent that those are not excluded, which occur within one year from the date of the invoice
Jul 26, 2019 at 8:11 AM Post #1,033 of 1,535
That makes more sense and easier on the mind. I'm almost ready to pull the trigger on 3.1 depending on how the audition over the weekend goes. It will be a tough choice between 3.1, TC, Susvara and SR1a.
Jul 26, 2019 at 8:20 AM Post #1,034 of 1,535
You are welcome, I am on the way now... We meet in suite 11 there..
Best regards, heinz
