MORE....
My first attempt at a valve energiser. It is the TubeCAD of November 1999.
Modification based on the same circuit.
Some more mods' and a PSU on PCBs cut on my home CNC.
SMPS's now used for valve heaters, much better.
PCB mount Triads for the power rails.
Heater SMPS and Vdc bias with a 48v transformer and x8 multiplier,.. more detail as to why I prefer this method later....
Close up of the Triads, PCB mounted.
This is the PCB I have just CNCed for the valve energiser. I will build it later this week, when I have time.
I use CadSoft Eagle FreeWare and PCG-GCode ULP, also free.
These are my CNC panels. Various on 0.5mm FR4 and 1mm FR4.
Some here are the standard 2mm holes with pitch of 5mm, others are 1.5mm holes, with I think 4mm pitch,.. I can check....
Also some plastic spacers on 0.5mm sheet plastic cut with a compas cutter.
I will also try Neoprene spacers and both Mylar 2um and clingfilm diaphragms.
Later, another day I can show my home made diaphragm stretcher, it is a copy of one I saw on Google a while back.
I have many questions for you guys, hope I haven't bored you too much.
One day I hope to be at the same level as Wachara C.
Cheers,
David (Muamp).
