Hello Muamp,
thank you very much fo you input on the coatings. I will see that I can actually measure the resistance when I coat. There has been an interesting article in www.hackaday.com not long ago on measuring very small currents (
https://dannyelectronics.wordpress.com/2016/01/28/the-nano-ammeter-you-already-have/) what might be usefull to measure the resistance of a coating.
Thanks as well for correcting me on Elvamide, I was not aware that this is actually Nylon.
The link to the RS Antistatic spray is highly appreciated, I will put it on the order lift for the next batch.
@Wppk: please give us more detail on your fail with the UHU Contact.
I recently bought UHU Contact Gel. Tonight I tried it on Mylar.
I cleaned a plate of copper (ScotchBright),
Applied UHU Contact Gel to a ca. 6mm wide section. (Clear)
To another ca. 6mm wide section I applied Pattex Contact Gel (yellow)
I applied it as thin as I could (was quite difficult as it dried before I could distribute it the way I wanted)
About 2 minutes later I pressed some 3ym Mylar (DuPont Terfphane) into it, rubbed it flat with my fingers.
I could not smell strong dissolvent fumes any more, so I did not wait the time given on the glue canisters.
About 1h later I tried to pull of the Mylar, with the following result:
- when pulling in plane, both (UHU and Pattex) sides tore, the Mylar plastified first. I could not notice an creeping or peeling.
- when peeling the remains off (pulling in normal direction to the gluing plane, no shear force in the glue), the Pattex was quite a bit stronger than the UHU.
- The UHU gave the thinner film, the more flat joint.
I will repeat this with a longer curing period.
Both UHU and Pattex require both surfaces to be coated with glue (contact glue). Since I think this is not feasible for membranes I did not wait the recommended 10 to 25 min for the glue to dry. I wanted some dissolvent left active in the glue.
@Wachara and others: how long do you let the glue dry before you cut the membrane out of the stretched Mylar?
Greetings
Georg
