Is anyone in Europe interested in a Purple Fuse?
Musician Audio Pegasus R2R DAC
Johnybuchar
What is your experience with the burn-in-time in case of Pegasus? I have an experience with Draco and 300h is minimum from my point of view.
Next question is related to fuse upgrade. Is possible to open the DAC without warranty loss?
Thank you for your feedback. Pegasus flyes .....
I would say 150 hours for burn-in.What is your experience with the burn-in-time in case of Pegasus? I have an experience with Draco and 300h is minimum from my point of view.
In theory you loose warranty after opening up the chassis. But if you are careful not to leave tiny scratch marks I can't really see how one could prove the chassis was open and the fuse swapped.
MaxA
BTW, does somebody tried to change the second fuse?
In Europe you only need to change one fuse as the 240V comes in through one wire. In this case the second fuse has no effect. In USA the 240V is split into two 120V channels, so you must change both fuses. I am sure some Pegasus owners in USA did the swap.BTW, does somebody tried to change the second fuse?
Johnybuchar
Thank you for the answer.
What fuse has "the best ration" sound/price under ~60e? HiFi-Tuning US-Supreme 3 Fuse?
@MaxA: is there any benefit to change second fuse when you can use only one voltage?
MaxA
It's necessary to change only one for my 230, but what is the practiceis there any benefit to change second fuse when you can use only one voltage?
Johnybuchar
Practice will be that one circuit can only work because of respective voltage i.e. second one must be shutdown. But let's try it if you have to get evidence .
Johnybuchar
Did you encounter "harsh" high frequencies during during burn-in period? I can still hear it however DAC is running almost 9 days. I don't have similar experience with Draco. Thank you for information.
sajunky
Ultra low jitter clocks make sound harsh during burn-in period. First three weeks are critical. You will observe improvements since now. Standard oscilators sound standard from the beginning. Ladder burning is shorter and less intrusive.Did you encounter "harsh" high frequencies during during burn-in period? I can still hear it however DAC is running almost 9 days. I don't have similar experience with Draco. Thank you for information.
Johnybuchar
Wow, thank you for important experience. Do you mean low jitter clocks in Pegasus? I use Auralic Femto that has own clocks.
BTW: does Draco use different integrated clocks?
sajunky
On the USB connection Pegasus will use its own clocks. It works exacrly the same as on the PC when reading files from the hard drive. Upgrading clocks on the hard drive do not increase quality.Wow, thank you for important experience. Do you mean low jitter clocks in Pegasus? I use Auralic Femto that has own clocks.
Try Coax, as on the S/PDIF connection quality mostly depends on a low jitter source.
Johnybuchar
Ok, I will try digi coax at least during burn-in time. Thank you for the advice.On the USB connection Pegasus will use its own clocks. It works exacrly the same as on the PC when reading files from the hard drive. Upgrading clocks on the hard drive do not increase quality.
Johnybuchar
Coax sounds more pleasent especially higher frequencies but USB connection takes me by extraordinary energy and space .... so addictive however Pegasus requires burn-in.
I am going to try Toslink today.
BTW: AES/EBU cable is on its way.
Johnybuchar
Only small update .... AES/EBU cable (SommerCable with Neutrik gold pins) sounds nice, no harsh high frequencies. I am happy with that .
Slight tube rolling confirmed great result with Musician DAC in my audio system.
Next stage .... fuse rolling ))
