Swapping the fuse(s) for the SR Purple one(s) enhanced clarity and staging quite a bit to my (and some other's) ears. I was sceptical, but it works.New Pegasus owner here. Have any of you guys tied any hardware modding, like changing caps in power supplies?
Musician Audio Pegasus R2R DAC
I heard about the SR Purple, but I won't spend that amount on a fuse. Any budget options here?Swapping the fuse(s) for the SR Purple one(s) enhanced clarity and staging quite a bit to my (and some other's) ears. I was sceptical, but it works.
ColSaulTigh
I've not tried them in the Pegasus but the Hifi Supreme are fairly good for the price:I heard about the SR Purple, but I won't spend that amount on a fuse. Any budget options here?
https://www.partsconnexion.com/FUSE-74700.html
I‘ve both, SR purple and Supreme 3 in my two Pegasus. S3 is not as good as the purple one, but still a great improvement over the stock one.
MaxA
Noetech 1020 is fine for me and cost not a lot. Don't even want to change itWhat cables would you recommend for the Pegasus?
Do you mean the USB? What about power and interconnects?Noetech 1020 is fine for me and cost not a lot. Don't even want to change it
Rest of my setup is: WHAMMY + HiFiMan HE6SE
ColSaulTigh
Quite welcomed!
I used Worlds Best RCA when I ran them to my Woo WA6-SE's. For power, I bought Monosaudio cables from.Amazon. nothing too elaborate. The fuses made far more difference (IMO).
I'm thinking about grabbing a pair of Oyaide RCAs for WHAMMY. PA-02 or maybe a Tunami. I like them a lot. Power has to wait for now. It's the last in the order. Need to get a good speaker amp first. Schiit Audio Gjallarhorn sounded pretty good TBH. The arrival of the Pegasus pushes me for some changesQuite welcomed!
MaxA
Yes, USB, Neotech NEUB-1020 1m.Do you mean the USB? What about power and interconnects?
Oyaide Tunami Terzo RR V2 (Japan) as interconnect
SEAC 7000 + IeGO 8075-Rh as power cable, self assembled
I use Jcat Femto + iFi iPowerX as desktop USB out
Changed Pegas power inlet to original Fuructech aslo. Didn't understand was there some difference or not. Don't like the "looks like" differences )
My friend canged it to Viborg and heard it. The fuse replasement wast really bright and clear, no any doubts
MaxA
I didn't like them as power cables, interconnects are greatTunami
So the used inlet is not genuine Furutech? That's a shame. I need to check mine. Maybe a cable choke and no IEC inlet at all wouldn't be a stupid idea...Yes, USB, Neotech NEUB-1020 1m.
I was looking at SAEC 650 speaker cable yesterday, funnily enough. Great minds think alike How would you describe that SAEC cable? They aren't that popular in PL.
Power cables were okay for me, the speaker cable left me kinda unimpressed.I didn't like them as power cables, interconnects are great
MaxA
I don't know, I bought it on eBay, it was the japanize lot and sender address also. I'm sure that it's avaulable to buy original Oyaide cable mot in Japan onlySo the used inlet is not genuine Furutech?
For example, I'm sure about this cable, but too expensive in Europe
https://www.audiophonics.fr/en/cabl...-xlr-interconnect-cable-13m-pair-p-10616.html
I have this one from preamp/headamd to subwoofer, but one XLR side replaced to RCA. RCA-RCA Oyaide from Pegas to Schiit Lyr
https://www.audiophonics.fr/en/cabl...r-rca-interconnect-cable-1m-pair-p-15371.html
Bulk Oyaide Tunami XLR-XLR Dynaudio 9S to Genelec 8010. That's crazy multimedia setup )
Yeah, Oyaide raised prices in Europe significantly in the last two years. They are still good, but not as much of a steal as previously.I don't know, I bought it on eBay, it was the japanize lot and sender address also. I'm sure that it's avaulable to buy original Oyaide cable mot in Japan only
That is a crazy setup you got!
I changed the inlet to Furutech Rhodium ncf and prefer it to the original. It seems to be more dynamic.
