I got a set of these a few weeks ago. They've developed a problem with low right channel volume. When I switch the cable entries around the problem remains on the right side, so it's either the cable jack or the driver, not the cable.
Have there been any other reports of faults like this? I'm in touch with Australian supplier so hopefully they can help me out.
This usually indicates a broken driver trace and is a service issue. Our Australian distributor will help you out.
Timely post - I have just encountered the same issue with my set, which I purchased about two months ago or so. I've been in touch with the store I got them from (Minidisc) and will likely return them for...repair? Replacement? Whatever needs to be done to rectify it. It's quite annoying as it's ever so slight but enough to make the listening experience uncomfortable in a way.
Yes, this needs to come back. You can contact us directly if you're in the US. The simple service needed test is as above, if you swap the L/R cables and the problem doesn't move its the headphone. If the problem moves its the cable, amp or source.
Hello Dan,
Any plans to sell a Kit for modders to emulate the changes you made for the MD Aeon Open X? A kit that includes new paper for the drivers and the fenestrated ear pads? It would be great for Aeon Flow Open owners like me.. Thanks!
You can purchase AEON 2 Open ear pads and get a similar result to the drop. Not identical, but close.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
