orangecrescent
Just want to say hi here. Bought a S8 and gee I can't imagine an iem can present a soundstage that's outside of your head. Amazing.
I buy spiral dot ++ from amazon. They are slightly better than the standard spiral dot. Full disclaimer: I don't use spiral dot ++ as my main. I use Final E.Great insights! Seems spiral dots aren’t readily available in the US - at least on Amazon they are limited to very few size selections, and are very expensive. Do you know of sources?
Noted, we’ll try to reproduce the bug then solve@MOONDROP i received my Nekocake yesterday and it makes the bluetooth on my Mac go wild. If i use the Nekocake nearby my iMac the devices connected to the bluetooth on my Mac will disconnect
Stay updated on Moondrop at their sponsor profile on Head-Fi.
Can you pm us some detail about the mac model and disconnected devices?@MOONDROP i received my Nekocake yesterday and it makes the bluetooth on my Mac go wild. If i use the Nekocake nearby my iMac the devices connected to the bluetooth on my Mac will disconnect
You have got a PMCan you pm us some detail about the mac model and disconnected devices?
Tip rolling really helps with the fit, the best tips I found for me are the Spiral Dot++, followed by the Spinfit CP 100. The CP100 is actually even more comfortable but soundwise the Spiral Dot with deep fit is the best IMO.I just received the Blessing 2's, grabbed them on a black Friday deal for £200, I didn't realise the nozzle was 7mm!!, even on the smallest tip they are a tight squeeze so not sure I'll be keeping them yet, they sound very nice, maybe a touch fatiguing in the upper mids, I don't feel that they are neutrally tuned, maybe the the Dusk's fit that criteria a bit better, I just feel they could do with a bit more 'body' to the sound, they don't sound 'natural' to me, probably doesn't help that my daily driver has been the HD6XX's recently!
I own the HD6XX and HD600 are my main reference, and I also felt they were a bit bass shy. I believe they are tuned more with the Diffuse Field target of neutral in mind (also used by the Etymotics series) and to my ears that target needs more low end. The Harman target variants sound more balanced to my ears in regards to the lows (although I know our ears adjust to new sounds over time).I just received the Blessing 2's, grabbed them on a black Friday deal for £200, I didn't realise the nozzle was 7mm!!, even on the smallest tip they are a tight squeeze so not sure I'll be keeping them yet, they sound very nice, maybe a touch fatiguing in the upper mids, I don't feel that they are neutrally tuned, maybe the the Dusk's fit that criteria a bit better, I just feel they could do with a bit more 'body' to the sound, they don't sound 'natural' to me, probably doesn't help that my daily driver has been the HD6XX's recently!
Try the PEQ I posted above - it mimicks the Dusk tuning.I agree Dusk is probably going to sound more balanced to both of us but I haven’t tried it.
Thanks I'll give that PEQ a go, I actually have spare pair of Spinfit CP100's, I didn't think to try them as thought they wouldn't fit, was considering getting some Spinfit CP500's.Tip rolling really helps with the fit, the best tips I found for me are the Spiral Dot++, followed by the Spinfit CP 100. The CP100 is actually even more comfortable but soundwise the Spiral Dot with deep fit is the best IMO.
Regarding the tuning try EQ, you can try the PEQ settings shared by Toranku (attached)
Cool thanks!Try the PEQ I posted above - it mimicks the Dusk tuning.
