Blurry
- Sep 4, 2011
What is that case?
It's called Shell case, I bought it on Taobao. you could probably find something similar on Aliexpress
What is that case?
Shellcase I saw it I’m Shopee to around 30-40 usdIt's called Shell case, I bought it on Taobao. you could probably find something similar on Aliexpress
JVC spiral dots will fitCan anyone point me to good replacement tips for blessing 2? It seems like the stem is very thick and even a pair of tips that fit 5mm does not work. Seems like we need 6mm and bigger. Many thanks!
make sure the tips and the nozzle are completely dry from any oil , including the inner part of the tip boreThanks a lot, but it seems to be a bit difficult to get in US. Also it is a bit pricey. Is there some cheaper ones at <= $10?
I had good experience with different Spinfits. Also used Spiral Dots but preferred the Spinfit.Can anyone point me to good replacement tips for blessing 2? It seems like the stem is very thick and even a pair of tips that fit 5mm does not work. Seems like we need 6mm and bigger. Many thanks!
I think I am using the 155 on the Blessings. Have the 500 too, but the rounder umbrella shape of the 155 sits much better in my concha.Which one from SpinFit do you prefer? I think all those models with 5 in the model number will work. I am looking at 155 and 500.
Spingfit are really cheap when order direct from China around 3 bucks a pair. But have to wait for deliver many days.
Ok thanks for the heads upGotta warn you though, I think I've gotten fake Spinfits from Aliexpress (china). Bought a bunch of spinfit CP100s from them at the last sale.
They look the same externally, but they feel much stiffer than the originals I bought from an authorized vendor. Soundwise they are also slightly different, I'm not sure if this is unit variation or a new batch having different materials. I heard DUNU produces spinfits now, so perhaps if you wanna buy from Aliexpress, buying from them is safer than from one of the other small shops on Aliexpress flogging it for very cheap prices.
