FastAndClean
Previously known as presata
I listen to a lot of electronic music, was trying to get away for a bit and listen to more "normal" music, it didn't work out for me.
I decided to start experimenting with DSP to elevate the performance of B2 for breakcore, DNB and IDM.
Mainly larger sub bass impact is desirable for those types of music for me, also more air to give the impression for bigger stage size.
The DD woofer is capable and very responsive to EQ, there was no need to go crazy there, 3-4db in the low bass is more than enough, lowering the mid bass is a personal preference, i don't like mid bass boost at all even if it is small, treble drivers are capable also so there around 2.5db in the upper treble is enough.
With that preset i was able to lock them in nicely, sub bass impact is larger now with the same amazing control and dynamics, even cleaner profile after the mid bass reduction, upper treble is greatly improved as well with only 2.5db, if you are into electronic music try it out, who knows, you may love them even more.
For other music like jazz or country with male vocals, that preset is not good, it takes a bit of the body in the male vocals and the fullness of the instruments in the mid bass.
But for Autechre, Ochre, Squarepusher and Venetian Snares the performance is improved significantly.
