HerrXRDS
- Dec 27, 2014
Height 20mm, width 16mm and depth app. 23mm
What are you planning to do with the measurements?
Do you happened to know the nozzle diameter?
i dont agree with him about the treble, he is using foam tips, the KP actually can be bright, with very wide bore tips they can be a treble head dream
i am very close to pull the triger on the regular Kanas, someone stop Me please
Stop, you don’t NEED it
regular Kanas is darker and bassierI was close to buying regular Kanas, but then I've found a perfect tip that brought more energy up to upper-mids and now drums are finally punchy to my taste (well, at least 95% of the time now). So my urge to buy a new IEM is tamed for now.
Probably I'll save for Amadeus and get a cheap MH755 for the lols.
I have the CCA C10, which is almost carbon copy of the ZSN in form factor, and the Kanas Pro is bigger/longer than it. It really depends on fit and tips though as my girlfriend has smaller ears than me, and the Kanas Pro fits her perfectly with AET 07 size M. The CCA C10 with the same tips didn't fit her ear at all.Thanks. I'm assuming the 23mm includes the nozzle length?
Nothing, just trying to get an idea of the actual size as I have fairly small ears.
I am curious if the sale will pick up on Massdrop after this.
Oh, is that a massdrop exclusive then? Or did they just post the pictures of the Kanas and not the real Kanas Pro?I wouldn’t mind the MD one since it’s a matte finish unlike the original. However the ship date is end Feb...=\
I think it’s just that the photos look matte. The description clearly describes a “highly reflective housing.”Oh, is that a massdrop exclusive then? Or did they just post the pictures of the Kanas and not the real Kanas Pro?
Why’s that? 755 is better?
