DynamicEars
- Jan 5, 2019
Thanks @vault108 for your efforts and opinions! Very interesting!
It also makes me feel like I totally made the right choice with the Kanas Pro.
Based on your measurement (and others) I tried bringing the vocals forward a bit by boosting the 2k and 3k points by 2dB each.
I use the HiBy R3 as source for Mojo, and normally switch off all DSP to get the clean, unmanipulated signal to the Mojo.
Using the EQ does push the voices forward slightly, but at the same time the digital signal processor in the R3 kills the magic of the Mojo.
The good thig is that I don't feel the mids lacking any more, as I did at some point.
That's interesting and I wonder if I just got used to it or if it's a burn in effect. Someone was referring to such an effect.
They have been burning in for at least 100 hours and sound really good with the foam tips and I am very much looking forward to getting my customs tips made next week.
Honestly also a bit nervous if the tips will alter the sound... I like it so much as it is!
From the graph that @vault108 provided, I think you should boost EQ like this :
20hz +2db to up sub bass and its extension
30hz +1db to up sub bass
from there they are all very great, i cant believe this perfect tuning. Most of iems out there have boosted mid bass that bleeds reach until 200-100 territory, tendency for muddy.
800hz +2db to bring forward mid (male voices)
1khz +3db to bring forward mid (male & female voices)
2khz +5db to boost extension of female voices and details of some instruments
2.5khz if possible +5db to add details of some instruments and made overall sound become a bit wider and brighter
leave 3khz as it already good enough
6khz +1db if you like more sparkle on treble
Please do not over do it
Feel free to try this but,
just take it as grain of salt since i dont have KPE yet, but going to press [ADD TO CART] button soon enough.
Im an EQ man, always EQing all my iems to reach target and from the target (i use 2018 harman reference for that) i adjust a little bit for my taste. My taste is a deep big sub bass, clean mid bass, little forward mid, a little bit sparkle, much air. Other than that, soundstage, layering, depth, clarity, micro details cant be reach with EQ, it all depends on how good an iem is.
Im listen to vocals, pop jazz, pop, jazz, soul, and all technical sound recording like binaural etc.
