Moondrop Kanas Pro:
It is slightly heavier than A8 and Blessing but much lighter than Andromeda S. The fit is really good. I like that it’s made of metal and it cool your ears. The nozzle is big with grill. It is the smallest earphones of the three.
The bass is punchy. The vocal is more elevated than BGVP DM6 but slightly less than the Blessing. Details are good. The mid bass doesn’t drown the vocal or mid in certain songs like the DM6. Instruments separation is slightly better than the DM6.
Moondrop Blessing:
It’s very light. The fit is good. The nozzle is slightly bigger than Kanas Pro with three crossover opening holes. It is slightly smaller than the A8.
The bass is tight and not boomy. The vocal is slightly more elevated than the Kanas Pro and clearer. It is slightly more detail than the Kanas Pro has better instruments separation.
It come in a wooden box with leather looking small pouch like the A8 ane black 2-pins cable.
Moondrop A8:
It’s about the same weight and size as the BGVP DM6. It will stick out of your ears. The fit is almost the same as the DM6. It has the biggest nozzle of the three with 3 crossover opening holes.
The bass is in between the Kanas Pro and Blessing but leaning toward tighter. Vocal is definitely the showcase of this earphones. The details and instruments separation are ever so slightly better than the Blessing. It sound refine, balance, and really good.
The 2-pins opening is flush and not recessed like on the Kanas Pro and Blessing. All three Moondrop earphones do not have indication of left or right so there is a slight effort in connecting the cable. It come with the same copper and silver cable as the Kanas Pro.
The Moondrop seem to emphasize vocal and detail. They are all slightly different. It’s hard to put a value to them. BGVP DM6 is not bad when comparing to the Moondrops, it has different sound signature. The DM6 emphasize boomy bass more.
Graphs were done in REW using MiniDSP EARS and iFi micro iDSD Black Label.
I will be burning these for further comparison.
