Excellent. I would sure miss mine if it was gone for very long.
Moon Nēo 430HA Reference Headphone Amplifier
- Thread starter Icenine2
TGBerland
- Mar 3, 2017
I have 2; so brought the one from the office back home during the wait.... Had a Sennheiser HDV 820 loaner (used it at work); it was _so_ bad when comparing to the 430.Excellent. I would sure miss mine if it was gone for very long.
Sage Encore
Hi Sir,Received my Moon 430HAD (it has been available for a while, just no time to pick it up). Power supply replaced; all good in the Moon-world again
Were the Power Inverter and Relay switch the culprits? Looks like mine is gone and need replacing. I have ordered them. Was yours under warranty? As mine was bought 2nd hand, the warranty was not transferable. Lucky the parts were cheap. Hope they are in by today to be replaced, and then hopefully she fires up again. I have also bought some SR20 fuses for her. Hope everything turns out fine.
Enjoy your music.
Ive been thinking of upgrading the internal dac of my 430had. Was going for the Yggdrasil 2 but have been Reading that Hugo 2 dac is equal or better then the Yggdrasil? @Currawong also wrote this. Anyone tried the Hugo 2 and Yggdrasil with the 430ha? Any inputs before i pull the trigger on one of these?
Thanks
Thanks
I use a second input and use my PS Audio DirectStream DSD DAC with the 430HAD. I go back and forth between the two DAC's for variety.
buzzlulu
- Nov 27, 2003
Shameless plug - If anyone is interested PM me as I am considering letting mine go. Less than 2 years old - original owner warranty.
I am just too deep into STAX . (its addicting)
I tried A-B with my lcd 4 from 3,5mm out of ipad pro. And 4pin xlr from the 430had. I cant understand that there is so small of a difference in sound between just an crappy ipad and my desktop. On some songs i cant Even tell the difference. How could that be? if im using tidal app on ipad pro, its a huge difference since it doest provide enough volume. But roon does!
Does the break in period of 300 hours make a difference with this amp? Have just purchased a new unit and I'm a little underwhelmed with the sound if I'm honest.
john777
- Jun 3, 2013
It does take awhile to break in, as most will confirm. Stick with it...
Will do!
Will the hi gain bring in more noise than the lo gain setting? I think i can hear less background noise with low gain in some recordings. ?
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
This is almost universally the case for any amp. Whether or not the amp "sounds" better at low or high gain is up to debate, assuming all levels and headroom are the same otherwise.
mitchb
- May 13, 2007
As my Moon 430HA is burning in the sound with my new LCD4 phones is absolutely spectacular! During the burn in it can be a little frustrating as it is a roller coaster ride with good sound and not so good sound but from what I’ve heard this evening it’s worth the ride.
