jacobap100
- Dec 5, 2010
which one is the best for
Sound
Comfort
Isolation
Bass
Clairty
Sound
Comfort
Isolation
Bass
Clairty
Sound- Ue tf-10
Comfort-Monster
Isolation-Ue tf-10
Bass-Monster for quantity and tf-10 for extension/punch/speed
Clarity- That's a joke Tf-10 by far. You just can't beat the drivers in the tf-10 with a dynamic earphone when it comes to clarity. Imaging perhaps.
Quote:Sound- Ue tf-10
Comfort-Monster
Isolation-Ue tf-10
LOL, notice we pretty much typed in the same reponse?
Sound- Ue tf-10
Comfort-Monster
Isolation-Ue tf-10
what do you mean when you say extension/punch/speed i heard the coppers had an amazing sound
Have you tried all three
ok thx I think I will have to decide between the coppers and the triple fi
I dont want them sticking out of my ear and I listen to hip-hop and rap so I need bass
Quote:what do you mean when you say extension/punch/speed i heard the coppers had an amazing sound
What does the coppers having an amazing sound have to do with anything?
Yes, I have tried all three in fact I had at the time my tf-10 with me when i demoed both of them with my own setup.
Extension simply means the tf-10 to me reaches sub bass levels and really goes deep (Also, might mention it does indeed depend on how long it stays). Punch and speed are superior due to the armatures and the oscillations that are forced out of the housing. That just means the bass is more hard-hitting and the rhythm appears to be faster. It doesn't mean that there is more bass then the monsters.
Quote:ok thx I think I will have to decide between the coppers and the triple fi
Be weary of the fit. They might not be comfortable for your ears. As for me they fit fine./
The TF10 are perfect for rap. Same sound sig as a car stereo you hear going down the road lots of treble and lots of bass, lots of bass impact. If amped it will make your eyes cross from the impact. I ran my TF10's from a Sansa Fuze - LOD- P-51 Mustang and the bass would literally make my eyes cross. Lots of impact and very punchy. The soudstage is nice and wide also.
