theangelboy
iv just today got mine an hooked um up to my jds atom an started to test them out to find my desired listing level an one of the drivers went out ,before that i was really enjoying them
my question is is that just somthing that happens time to time or did i run them wrong ,i didnt turn them up past half
with the atom in low gain mode at first but then i tried the high gain which i started with the volume at 1/4 which with
the high gain sounded as loud as half volume with low gain but about 2min into a track my left side went out, is that
because had to much gain an volume or was that just these cans........eather way iv already requested an rma to get a
replacement set because before the kicked it i really liked them ?....................Koan - Briar Rose Side B this album was sublime on them before the issues happened
That's a real bummer! But It definitely wasn't your fault the driver failed. If Monoprice's specs are to be believed it should be able to handle 10 watts of peak power and >130 dB spl. The Atom can only put 1 watt of power into the 32 ohm M565. Even with the amp at full tilt you should have been well below the capacity of the driver.
Your pair was just defective, unfortunately. Maybe bad solder joints on the driver? The solder job on these headphones isn't great. In any case, the rma process should be mostly painless so you should be jamming out to Koan again in no time.
