mbyrnes
I really like these for gaming. Figured I'd break them in with no critical listening yet. No connector issues. Really liking them so far.
This is with 5 minutes of listening. Yes that 5k peak needs to be tamed a bit, but a few db EQ cut does that no problem without needing to mod.
I have my EQ in Jriver set to cut 5 db at 5k with a Q of 1. Does this seem like a reasonable eq setting? I'm a bit hesitant to eq headphones but this setting does smooth out the upper mids considerably.
Hey guys quick question here how do the M560 and M1060 pair with monoprice's headphone amps?
Since cskippy and others posted graphs, the easiest starting point is to flatten the peaks you see in those graphs. Save that, then you can slightly boost other areas.
One suggestion I'll make is to try and not EQ any one area more than ~3dB or so. It tends to become really apparent when EQing any more than that IME.
This is what I came up with using Cskippy's graph. Does it look like a reasonable eq setting? It sounds like a big improvement but I don't trust my ears with eq.
