Sorry to hear that.I received the Chinese headband, it doesn’t fit…. yokes are too small….
Apart from that, the suspended headband is to short for bigger heads and they added a stick on pad for the top, which vitiates the purpose of the suspended headband design….
Ended up buying this after seeing someone use a HE560 V2 headband and apparently this one is really similar to it so fingers crossed that this will work!Anyone know if this headband would fit the M1570?
https://www.analogueseduction.net/h...iman-enhanced-comfort-headphone-headband.html
I purchased two as you had suggested.Wanted to share a nice deal on Amazon: Master & Dynamic has discontinued their wired IEM line, so they are liquidating their IEMs. I nabbed 2 pair of their flagship ME05 in brass, and just ordered a set in Paladium. They have a warm signature, and very smooth and full sounding, and sound similar to my M1570, just without the deep subbass extension. And, they're down to $7.95 a set. (Original MSRP $199, tho recently $60+) I don't believe there is any warranty, so buy 2.
Let me know what you think of them.I purchased two as you had suggested.
Thank you!
I recommend the HiFiMAN Sundara headband, which does fit these (slight tweaks needed for the pins, but the overall size is spot on). Not cheap.I received the Chinese headband, it doesn’t fit…. yokes are too small….
yeah, I´ve ordered one, but DPD screwed up...I recommend the HiFiMAN Sundara headband, which does fit these (slight tweaks needed for the pins, but the overall size is spot on). Not cheap.
Is there a guide for the swap? I'm curious. Also I assume changing out your headband voids your warranty?I recommend the HiFiMAN Sundara headband, which does fit these (slight tweaks needed for the pins, but the overall size is spot on). Not cheap.
You can email Monoprice Support and ask them if it does. I would think it would, but you never know.Is there a guide for the swap? I'm curious. Also I assume changing out your headband voids your warranty?
Page 18 of this thread. Someone made a post with instructions on how to do it.Is there a guide for the swap? I'm curious. Also I assume changing out your headband voids your warranty?
I would wait til the warranty is up, then experiment.Thanks guys on the warranty thoughts. I'll have to think it over. While on one hand a more supportive, lighter headband would be nice. But on the other hand one of the reasons I bought these is Monoprice's excellent 5-year warranty. Wouldn't want to mess that up.
They sound great for the money $7.95. Less bass and clarity than $14 CCA CRA. But the accessories are well worth the money. Great deal for some backup IEM.Let me know what you think of them.
