Bleezy
Just submitted an order for the mk3. 12 weeks to go
What ye guys powering them with? I was using an xDuoo TA-01 which had plenty of power 2100mw @32ohms.
Emotiva A100 which is perfect. Pumps roughly 8w into 50 ohms and these phones seem to be able to take that sort of power without distortion.What ye guys powering them with? I was using an xDuoo TA-01 which had plenty of power 2100mw @32ohms.
Nice, I like it. Do you recall the size of the heat shrink you used?Mine:
Took the headband covering off and heat shrinked the metal band before sending them off for the Argon modding. Temporarily taped the wire going across the headband, will be 3D printing some retainer clips for it. Using with Gustard H10 which is specced to provide 2.7watts @ 50ohms.
3/4" Tech-Tron TT100 from FRYs - have quite a bit left if interested, only needed about a foot out of a 4-foot stick.Nice, I like it. Do you recall the size of the heat shrink you used?
Mine:
What about the soundI just received mine! So happy! I'm impressed by the comfort of these.
What earpads are you using?So far I think that the bass is wonderful. It has the right amount of body and weight for my liking (these are definitely my bass-head headphones). The sound-stage is immensely wide, although I don't think there is as much depth. The highs are there, but I believe that a tad bit behind the mid-range and bass. The mid-range is great -- it seems neutral to me. These honestly sound a bit like a U-shaped sound signature to me.
These are also amazing for gaming and movies.
Lambskin .. but I might switch to protein leather because my ears do get a bit sweaty with the real leather.
I also ordered the deer-skin strap from Mod House Audio because the Massdrop T-XO strap doesn't hug the head much.
I wish these stayed more securely on my noggin', but maybe I'll just bend the headband in more!
