Sambones
- Feb 17, 2009
Here are some suggestions from my own experiments on other headphones:
1. Procure a pair of circumaural earpads.
2. Cut a piece of carboard to the same size as the baffle on the set those pads were meant for.
3. Cut away enough of the "baffle extension" for it to fit under the Kanen's baffle, around the mounting screws.
4a. Either cut a slit in the carboard "baffle extension" to slip the internal wires through, or...
4b detach the internal wires, run them through the carboard ring, and then resolder them to the driver.
5. after closing up the freshly engorged earcups, tape or glue the former earpads to the headband. Cut them in half if you want more than just the top padded.
I can dig up the pictures I made of the process, but they're somewhere on FB, quite crappy, and don't cover everything.
