FallenAngel
That's backwards
Tip is left, ring is right.
Originally Posted by nullstring /img/forum/go_quote.gif What pot do you have? |
Originally Posted by netsky3 /img/forum/go_quote.gif Wich one is the base version of this amp? I hope to build one of this in the future, how much is the cost of the pcb and all the components necessary? (without case and other stuff) |
Originally Posted by ezzieyguywuf /img/forum/go_quote.gif <snip> Finally, with my source set at 0dB volume, I can barely touch the pot on the amp before it is too loud to do anything with. Its like off-off-offf-off-SUPER LOUD. The only reason I mention this is that on my CMOY, I can use the same source at the same volume and have a fair bit of play with the volume knob. </snip> |
Originally Posted by ezzieyguywuf /img/forum/go_quote.gif </snip> I did not use an R16/R17 as they are marked "optional". Decided to go with the simplest build possible. (already over budget ya know). I do have some spare resistors though, so what would you suggest? |
Originally Posted by nullstring /img/forum/go_quote.gif lol, you shoulda done a bit more research. Anything from 33k to 150k or so should work fine... just make sure they match. [EDIT: you should probably add R14/R15 as well if you have any spare resistors in the 1K area.] What pot do you have? It won't actually fix the mismatch.. you just won't be using the pot at the very low end anymore. |
Originally Posted by Sganzerla /img/forum/go_quote.gif Well, let me first thank you both for your time and attention. Here are the links for the 4 images I made: LINK1 LINK2 LINK3 LINK4 Yes, they do. Looks like they fade a little from the intensity they are at start, but they continue lit up. I have problems with terminology of these components, could you point wich value (or the color) are the power caps and the output caps? It is easier for me to understand. Thanks again! |
Originally Posted by m11a1 /img/forum/go_quote.gif Darn it, I'm so frustrated. I had a problem with volume imbalance on my SSMH. Originally, I had actually thought that the problem was because one of the MOSFETS but after getting new MOSFETS, the problem still exist....arg! Now that it isn't the MOSFETS, I have no idea what is causing the volume imbalance anymore.... |
Originally Posted by ezzieyguywuf /img/forum/go_quote.gif Wow great post tomb. I'll be checking those things if my bad solder joint doesn't turn out to be the culprit. |
did the addition of those resistors and removable the alligator clips not help? |
