smeggy
Member of the Trade: ThunderpantsTP1
- Feb 9, 2004
Oooh, good news indeed!
It'll be nice having a real board
Originally Posted by luiztfc /img/forum/go_quote.gif Guys, I'm trying to build the Starving, but I'm having a hard time to finding these 19J6 tubes. Are missing? |
Originally Posted by -=Germania=- /img/forum/go_quote.gif Here are some readings I just took using my auzen soundcard on my computer. Not the best, but the readings seem pretty darn good. |
No fancy cables, just good ole' Beldens for the readings. |
Originally Posted by n_maher /img/forum/go_quote.gif Let me know when you start to be able to measure the difference cables make. If anything other than shielded vs. unshielded shows up you've got big problems. |
Originally Posted by -=Germania=- /img/forum/go_quote.gif Unloaded, didn't have any 32 ohm resistors to represent the headphones that I own and actually listen to. |
Originally Posted by zkool448 /img/forum/go_quote.gif Hang in there, luiztfc. It looks like it won't be very long before beezar.com will officially start selling the kits |
Originally Posted by luiztfc /img/forum/go_quote.gif Ok, but isn't there any other tube that can replace the 19J6? |
Originally Posted by kuroguy /img/forum/go_quote.gif I work with a schematic and a highlighter, coloring in the lines and components as I install them. when the schematic is completely highlighted, you're done. |
Originally Posted by Logistic /img/forum/go_quote.gif I posted a guide to use the 12sr7/12sw7 tubes about 10 pages back. Just search this thread for 12sr7. |
Originally Posted by luiztfc /img/forum/go_quote.gif Thanks, I'll look into it. And just a last question: is there any possibility that the 19J6 model name can differ in different countries? |
Originally Posted by cactus friend /img/forum/go_quote.gif Just so everyone knows, I was able to order two same brand 19J6s from Jack at thetubecenter.com - not sure how many they have, but it's worth a shot if you're hunting them down. Also, a quick question: Those black o-rings around the holes for the transistors (for instance, in Nate's build), what are those called and where could I find some? Pardon my ignorance - thanks! |
