jamato8
I'd be interested in seeing some quantitative measurements that lend credence to this. The ceramic fuses aren't filled with sand for this reason, but to absorb heat. So quite possibly, this theory could be yet another case of audiophilia gone awry... or not. It'd be interesting to know. On the other hand, ceramic sand filled fuses aren't cost prohibitive to try out for the heck of it. My local Radio Shack used to sell them.
Operation
Under normal operating conditions the current flowing through the fuse element does not provide enough energy to melt the element. The heat produced is absorbed by the surrounding silica sand.
If a large current flows the energy produced melts and vapourises the element.
The time taken to reach this point is known as the pre arcing time. The high prospective fault current is ‘cut off’ although an arc will still be formed. The heat produced by the arc causes the fuse element to fuse with the silica sand and for the silica sand to absorb the energy. This has the effect of extinguishing the arc and stopping further current flow. The time taken to reach this point is known as the total clearance time.
