dpump
- Jun 23, 2001
There's no top currently. I'd be tempted to just drill the existing top, but that might hurt resale.
Urban Audio sells a top for $30 that has the 2 holes already drilled to let taller tubes stick thru and allow the top to be screwed down. I have one on my amp with the 6F8G/VT-99's. There are some pictures of my amp with the 'holey' top in some earlier posts.
One note. I see bazelio got the VT-99 to 6SN7 adaptors with the white cap that attaches to the top of the tube. I personally don't like the white caps as they only contact the tube on 2 sides and tend to loosen with use. If you check eBay you will also see adaptors that use a black cap. These black caps contact the tube on 4 sides, fit much tighter, and tend to stay tight. There is also an eBay seller who sells the black caps separately. I would recommend anyone buying any adaptors to try to get ones with the black cap instead of the white one. I converted the adaptors I have from white caps to black caps, but it is a bit of a pain to do until you figure it out.
