Robeeert, I intend to change all Nichicon capacitors with ELNA Silmic II (or what are), becouse I know that Elna are a superior solution. In comparative tests, Elna are better in terms of tone realism, softness, dynamic, definition, etc. I am looking for this becouse electrostatics are very sensitive and respond immediately any change, no matter how small. On the other hand, Elna are very recommanded for classical and jazz music! It's those type of musical styles requiring refinement. Two friends use ELNA capacitors in an amplifier and a DIY pre-amplifier&converter and both are very satisfied with the result. ELNA give a musical and relaxed sound. I heard the sound and was very good. Piano and voice sounds so natural...
Other changes: I want to replace all film capacitors, three with Russian Silver MIca (0,01 uF) and the remaining six, if I thought well , with AUDIENCE AuriCap (0,22uF, 0,1 uf);
"Vampire" BNC connector for S/PDif digital input (it will provide a digital audio signal with a high amplitude). LEGATO is equipped with only bnc connector and now, I use an adaptor (rca>>bnc);
On this occasion, I will remove the two stock-film capacitors (C5, C25).
In terms of output capacitors, I keep V-Cap! I dont't know how much I would encourage Mundorf cap., anyway polypropylene capacitors are very good conductors and in terms of performance! On the other hand it comes and money...But I do feel clear what do these capacitors with electrostatic sound: give details, many details, and realism..
What is your opinion, about ELNA capacitors and stock-capacitors replacement (for Havana)? Worth movement? What you felt in sound, after you replaced? I think, after they...you say quietly you are in high-end audio headphone!
Thank You!
