LCMusicLover
Personally, I agree with you.I get what you mean but don't entirely agree. If you are spending 3k on a headphone you want to use it with the best amps surely? Most of the top ones are balanced these days one way or another.
Considering how easy it is to change plugs and the fact you choose on delivery it seems a missed opportunity to not have a larger range of options like for example MrSpeakers do with all their headphones. I ordered my Ether Flow with the XLR because I knew that is what works best with my amp. It isn't anywhere near the same effort or cost as including a full set of super car tires, a plug takes what 5-10 minutes to replace? I just would rather not have to modify a brand new cable and void warranty just to make it work with my amp or buy a new cable at increase expense!
I honestly don't think this is being unreasonable and it seems surprising the push back I am getting from this discussion...
Apparently headphone manufacturers can't decide how to deal with cables: provide a very basic cable because cables don't really matter or because they assume you'll upgrade; or provide a 'good enough' cable which will work for you, or not, depending on your other equipment; or offer a choice of terminations; or include multiple cables.
For me, at this price level, it ought to be either offer choice, or include multiple cables. Of course I own Utopia, which came with 1 cable that I have never used, and I've spent $$$ buying upgrade cables for it. And I own HEKv2, which came with 3 cables, only 1 of which I've ever used, and I've moved to a Silver Dragon for that set.
Meze seems to have taken the 'offer multiple cables' approach, but they've coupled it with the 'SE amps are as good or better than balanced amps' attitude. Maybe they figure that everyone who buys their cans will already have a nice balanced Audeze upgrade cable.
Or maybe they figure that only a very small number of buyers will be swayed by the inclusion or exclusion of a quality cable which works with their equipment. I mean, are you going to buy a HE-1000SE over they Empyrean because the HEK includes a cable that works with your amp (say 4.4mm TRRS), while the Empyrean doesn't? Probably not. You're probably going to buy the one you think sounds the best.
