racebit
- Mar 7, 2016
This was the response I got:
"If the only amp used was the chord TT2 it's going to sound vastly different than most typical amp setups. The chord amp/dacs are amazing and great - but they have extremely low impedance which makes the mids sound much further back and our high impedance headphones very different than even most regular solid state amps that have output impedances of usually 1 or 2 ohms. The chord tt2 has an output impedance of . 042 ohms."
Actually that is wrong. It is not the low impedance that makes any change. The opposite is true: low impedance guarantees no change is made to the headphone FR.
It is the higher amp impedance that changes and can correct the hp FR.
For someone not into electronics:
The amp and hp impedances are in serial. If the hp impedance is much larger (which happens with very low impedance amps such as all the Chord ones, not only TT2) then all the energy/voltage goes to the hp. On the other hand if the amp has a significant impedance then the energy/voltage is split between the two (amp and hp).
Now what happens with most headphones is that their impedance changes with frequency. For example my Focal Clear (55 ohm) has higher impedance in the bass region (300 ohm). Therefore if plugged into a low impedance amp (near 0 ohm) the hp receives all the energy equally for all frequencies and the FR remains unchanged. But if plugged to a high impedance amp, say 100 ohm, then the hp receives 300/(100+300) on the bass region vs 55/(100+55) on the remaining spectrum. That is about 2 times stronger bass on that region.
So if the hp (or the amp) do not have a constant impedance across the spectrum, the non-zero impedance amps do actually work as an equalizer, which can correct for the hp deficient FR. It is not the low impedance amp that makes anything further back!
Edit: Btw, Empy impedance (32 ohm) is flat (varying less than 1 ohm) over the full spectrum (20 Hz - 20 KHz), so amp impedance is not relevant with Empy.
