Andreas Bin Rudi
I recommend from Lavricables "Grand". I have tried many different cables, but the Grand is the very best. No sibillance, better clarity and imaging. Give it a try. The Liric plays in a complete different league.
3 weeks in with the Dekoni pads: They are starting to grow on me. Still using the same EQ as in the previous message. Liric is continuing to be an amazing headphone:I took one for the team.
Recently re-bought Liric and I think it's even more comfortable then I remembered. Also bought a pair of the Dekoni pads and swapped pads an hour ago.
Stock pads a softer, fit like a glove, sound amazing but are horrible with sweat (pleather).
Dekoni pads are firmer, feel like any other Dekoni pads and made of leather.
The swap is almost always irreversible. The chance that you destroy the glue/sticky tape layer of the pads is nearly almost guaranteed.
On to the changes!
I had to re-adjust the fit. Dekoni pads are less thick, the result is that the rods are less extended.
Ah the feel of leather! I prefer it over pleather any day of the week but respect other opinions.
The FR is changed but not overly dramatic. Here is my EQ using de RME ADI-2 DAC:
- Add some sub bass, but the difference in bass presence is less then expected
- Add 2.5dB at 4khz to bring back some of the missing upper-mid presence
- Reduce 2.5db at 10khz. The dekoni pads add more presence there.
These changes are done based on the FR on Dekoni's site:
Are they worth the effort / destroying the OG pads? I would say: no. So far I readjusted the FR to have it more in line with the OG pads but without the extra energy around 10khz was not to my liking. Comfort wise both OG and Dekoni pads are above most if not all closed-back headphones.
I'm using Lavri Master for my IEMs. Great company, great product indeed.I recommend from Lavricables "Grand". I have tried many different cables, but the Grand is the very best. No sibillance, better clarity and imaging. Give it a try. The Liric plays in a complete different league.
I use the provided case and wrap the provided case in a cotton shoe bag to protect it. If I cannot use the case, I just use the shoe bag but make sure I still disconnect the cable and pack separately. I then make sure it is padded well and that no weight can be pressed down on them. This is only for short travel. If I am going anywhere for time or distance, it is always the hard case.Guys, how do you carry your Lirics with you ? I really need the best recommendation for the slimmest case possible or a tough carry pouch
The shoe box idea is funny, I'm sure the audio world has come up with a smaller caseI use the provided case and wrap the provided case in a cotton shoe bag to protect it. If I cannot use the case, I just use the shoe bag but make sure I still disconnect the cable and pack separately. I then make sure it is padded well and that no weight can be pressed down on them. This is only for short travel. If I am going anywhere for time or distance, it is always the hard case.
I don’t use a shoe box. I use a cotton shoe bag.The shoe box idea is funny, I'm sure the audio world has come up with a smaller case![]()
Oh sorry , can you send a picture of it?I don’t use a shoe box. I use a cotton shoe bag.
It is not thick at all. It is just a simple cotton drawstring shoe travel bag. It keeps my LIRIC hard travel case from getting damaged and works for carrying the headphones when I don’t have the hard case, but I honestly recommend just using the hard case over the bag…but it works in a pinch. It looks something like this:Oh sorry , can you send a picture of it?
If it's a thick one and I am laying the Lirics at the top of my bag it would be nice !
Hi,Was on the verge of listing my Lirics that sounded bland and dull with the 320Max. Then I decided to try them with the WM1ZM2...
DSEEE On, DC Phase Type A Low, Vinyl Off. Getting very good dynamics and some nice sub-bass and slam out of these finally. The synergy these have together caught me off guard. Shall keep the Lirics longer heh.
Switched back to the stock pads after hearing them at a friend's place with the stock pads again.3 weeks in with the Dekoni pads: They are starting to grow on me. Still using the same EQ as in the previous message. Liric is continuing to be an amazing headphone:
- Closed-back
- (Trans)portable
- Planar
- Easy to drive
- All-day-and-night class comfort
All in 1 headphone! What the Dekoni pads add is the feel of leather, which I personally prefer over pleather.
After a weekend of fun with Liric i can safely say that it is not worth it to replace the stock pads by those that Dekoni offer for this headphone. I have a regained love for Liric since the pad swap.Switched back to the stock pads after hearing them at a friend's place with the stock pads again.
Dekoni pads suck out all forms of sub-bass these have so if you want some sub-bass in the mix steer away from the Dekoni pads!
Thanks for taking one for the team, arielext!After a weekend of fun with Liric i can safely say that it is not worth it to replace the stock pads by those that Dekoni offer for this headphone. I have a regained love for Liric since the pad swap.
