I have to correct the above statement. I was using the fixed output>Classic Amp. The variable output is a different story, the more the Daccord is engaged the better the sound, to a point, past about the 90% mark, the volume became too sensitive to adjust.
At the suggestion of another Head-Fi member, I recently tried experimenting OPPO BDP-105 DAC>Classic Amp>T1. and compared with 105> Daccord>Classic>T1. The Daccord Wolfson DAC blew away the Sabre DAC out of the OPPO. Significantly better clarity, soundstage and audio separation. Not even close. As a reference disc I used The Killers "day and Age." The T1 is the only HP I've tried so far, as it is far and away my best HP.
