Diego Dee
I can 100% confirm that the soul shows its best side again and again after 3 months. Every week I am amazed at the wonderful sound image together with my Ether2.
Never heard of those, how do they compare to ESS Sabre and AKM variants? (I.e ESS are rather bright)WM8741
I use it as a DAC, DSP, headphone amp, and preamp driving a power amp (Adcom 5800) and speakers (Magnepan 3.6).... interesting if someone try to use Corda Soul as preamplifier and amplifier ?
I tried to connect lcd4 but , maybe I didn’t find out right way to connect, the same with lcd3, but hifiman he1000se sound like never before, I’m really surprised how sound Dac, match better than other dacs which one hase real higher numbers, this guys knows what they doingThe mx4 has much higher voltage sensitivity than the LCD-4, a 50 mV output drives it to about 96 dB SPL. That means you're likely using the low end of the range of the volume knob. This reminds me of an important point. The SNR of most headphone amps is rated at full output. But nobody actually listens at full output, it's way too loud for listening. Typical listening levels are roughly 30 dB below full output. With conventional amp volume controls (both analog & digital), SNR drops roughly 1:1 with volume as you turn it down. So that means the SNR is roughly 30 dB worse than the specification. And with analog volume controls, the channel balance is typically uneven at the low end range of the knob.
The Soul is particularly useful for these highly sensitive headphones, as its volume control works differently from most other devices, addressing both of these issues. As you turn down the volume, it preserves high SNR, having low noise & perfect channel balance at all volume settings.
Indeed. The design and features of the Soul reflect that Jan considers both engineering and psychoacoustics in his gear.... this guys knows what they doing
