Meier-Audio CORDA Aria
Dec 8, 2005 at 7:04 AM Post #181 of 235
Kinda doubt it, USB is limited to 16 bit..
Originally Posted by ssingh0
does this mean that the ARIA sounds better out of USB than any soundcard (or other source?)
Will it sound better (or competitive) out of usb even with a emu0404??
Dec 8, 2005 at 7:40 AM Post #182 of 235
The usb fonction is very important for me as I'm using the motherboard sound system to listen to my loss-less audio files.
As it seem to be a great amplifier, it's the perfect combo for me.
Dec 8, 2005 at 8:19 AM Post #183 of 235
I think it is possible and depends on implementation.
My CEC DA53's USB input with ALAC-iTunes sounds better than the E-MU 1212M's analog out with wav->foobar ASIO.
Dec 8, 2005 at 9:11 AM Post #185 of 235
Huh? USB can handle at least 12Mbps in its most dumb form... its more than capable of supplying far more data than any DAC could possibly handle.
Dec 8, 2005 at 9:49 AM Post #186 of 235
Im not arguing it has the bandwidth. But for whatever reason, USB dac's do not support 24bit. At least i havent found one that does. Many support 24bit over SPDIF, but not usb. Probably somthign to do with the controller chip or internal spdif converters. I can't speak for other setups, but with my system there is a large and noticeable differnce between 16 and 24 bit. This is with an X-Fi. Now maybe the X-Fi has a sub-standard 16 bit implementation and a decent 24 bit, or maybe there really is just that much differnce. I don't know, but it's nite and day.
Dec 8, 2005 at 10:15 AM Post #187 of 235
It could be a Microsoft software implementation issue. I really don't know though.
Anyhow 24bit is nice, but there still isn't much open material in 24 bit except for those DVD-music discs. However a DAC should have 24bit capability just for future-proofing.
Dec 8, 2005 at 10:17 AM Post #188 of 235
...for whatever reason, USB DAC's do not support 24 bit.
Yes, I think you're right with the 16-bit limitation of USB.
...with my system there is a large and noticeable difference between 16 and 24 bit.
Just curious: What audio formats benefit from the 24 bit resolution? Such with native 24 bit, or such converted from the redbook standard, too?
Dec 8, 2005 at 10:46 AM Post #190 of 235
Oh I notice a large differnce with just Lossless Ripped CD's when outputing 24bit with Foobar.. don't know if that's a limitation of my soundcard or what, you'd think it should sound the same.
Dec 8, 2005 at 10:46 AM Post #191 of 235
Originally Posted by humanflyz
SACDs use 24bit, and I can hear a very noticeable difference between it and regular CDs that use 16bit.
I was referring to MikeW's X-Fi, not the hi-rez formats in general. BTW, the SACD format (DSD) is based on 1 bit, in contrast to DVD-Audio which has a max. resolution of 24 bit.
Dec 8, 2005 at 10:53 AM Post #192 of 235
Thanks! So it's Foobar's famous upsampling which is in play. It won't work with the Aria, but who knows, maybe its USB DAC sounds better than your soundcard's even without upsampling.
Dec 8, 2005 at 11:36 AM Post #193 of 235
should work with the aria in spdif modes eh? coax or optical.. unless the dac chip can't handle 24bit.. so foobar is actually upsampling eh? You know i hate foobar's ssrc, it kills the soundstage and is just blah, maybe I should give regular 16-bit a more critical listen somtime.
Dec 8, 2005 at 11:42 AM Post #194 of 235
should work with the aria in spdif modes eh? coax or optical...
Yeah, if there was some S/PDIF interface, but the Aria only accepts USB signals. Don't know about its DAC's actual (theoretical) 24-bit/96-kHz capabilities.
Dec 8, 2005 at 12:00 PM Post #195 of 235
The DAC accepts only 16 bit and 32-44.1-48 KHz as said previously. (no 24 bit nor 96 KHz even theoretically)
