tinyman392
Be nice to noobs, we were all noobs at one point in our life.
- Apr 27, 2011
I found their isolation to be above normal IEM standards, but definitely not like shure or westones. However, I chose not to compare that because shure and westone use foam eartips, which are naturally much more effective with isolation. As you said though, they definitely are sufficient for most applications.
I should mention that I am using the sony hybrid eartips, which fit much better than the stock ones. Way more comfortable
I actually use silicone ear tips with my Westone W4... Isolation is still either the same or better than the M6 Pro with foam tips.
