etteoh
- Dec 12, 2007
Bewildered D1 user reporting back with results from suggested troubleshooting. Here they are:
DAC section with no opamps - sound is distorted! What???
DAC section with no opamps and Headphone section with any opamp (LF353N, LM4562) - distorted! What again...
DAC section with LF353N and Headphone section with any opamp - channel imbalance at low levels (4th click onwards ok)
DAC section with LM4562 and Headphone section with LF353N - no problemo (clinical sounding though)
DAC section with LM4562 and Headphone section with LM4562 - perfecto!
I checked with the courier company and I will be receiving the additional opamps on Thursday - LT1364, OPA2107 and LME42970HA metal can with DIP converter. Let's see what happens after that. By the way, will it be safe to use the LME49720HA on the Headphone section? I understand Spanky mentioned this opamp having some DC offset.
Any thoughts / advice appreciated.
take out the center opamp all together, and try it with the headphone opamp plugged in only. And try all 3 opamps in the headphone position before you call it a night, I am curious. I would also try the RCA output if you have an adapter to plug your headphones into and see if there is any channel imbalance if you raise the volume to near max(since its not the amp it will be a little low)
Also the amp has some channel imbalance till about your 4th click in.
