Hey, talking about it, how do you like the Q5? I was thinking of saving up for that instead of a desktop setup because for the next 6 months at least I won't be staying in one place. But posts here have mostly swayed me away from that thought. But if it can get me 90% of the way there, I will start considering it again.
Also, if you don't mind me asking, how much did you pay for it? And where did you get it from? Thanks!
Well Q5 is a clear , clean presentation "audiophile" like quality.
It's natural and neutral with out peaks or dips with plenty of micro and macro details.
Let's say that it doesn't have a character of it's own.
Only minus it's a little bit on the lean side but it's still new I believe that it will improve.
So if you like your music a little warm or bassy or smoothed it is not for you.
Now aside of tonal preferences this is a quite expensive unit at about 400€ , mine bought from Greece but it was some kind of a deal - present and the optical in was a must.
So I believe you should consider the following - this unit will serve you well and worth the money if you are going to use it both on the go and at home and not invest on a separate desktop rig.
You should also be going balanced as it is designed to perform better as balanced out.
If you don't care about balanced and absolute portability then the ifi micro black is an excellent unit on the go that will also serve you very well as a home desktop rig.
If you just want a utility device for your travelling and later would be buying a desktop rig then skip on this.
You could do very well with Fiio q1 mark ii (balanced only) which is an absolute bargain or Schiit fulla 2 or dragonfly red or ifi nano idsd black do your 6 months listening and save for a better desktop rig.
