Mine finally arrive today. REALLY intrigued how they’ll sound balanced and in a balanced system consisting of a MJ2 and Gumby. My understanding is they don’t especially scale up that great but we’ll soon find out.
There’s so many varying opinions. Personally I just put music on (any) set them down and be done with it. Keep in on low/med volume. Others burn in with white/pink noise. Hell, sometimes I burn them in on my head jamming out every waking second when my wife isn't running my a$$ all over the place.Any tips on burning in headphones? Type of music, volume of playback?
This 1/8 output impedance thing has had me confused for some time now. According to your above illustration HD58X impedance is 150, then applying the 1/8 rule = 19 ohms.
My Project Ember headphone amp has 3 adjustable amp impedance settings (0.1 ohm, 32 ohm & 120 ohm). So using my HD6XX: 300 ohm divided by 8 = 38 ohm, that would mean that I should choose the medium (32 ohm) selection. As for my HD58X as you already mentioned is 19 so again probably the middle or 32 ohm selection. However I don't really understand what type of headphone requires the low output setting of 0.1 which would be for a headphone that has an impedance of roughly 1 ohm and the high setting of 120 ohm which would be designed for a headphone of 960 ohms.
Am I understanding this correctly, or not?
Hey, talking about it, how do you like the Q5? I was thinking of saving up for that instead of a desktop setup because for the next 6 months at least I won't be staying in one place. But posts here have mostly swayed me away from that thought. But if it can get me 90% of the way there, I will start considering it again.I have upgraded from Fiio Q1 markii to Q5.
Contrary to what i am reading i have to report that they do scale good very good.
Listening from the balanced output and thinking that this is the bargain of the century!
Burn in is a hot topic. I get review samples from audio manufacturers and they tell me to burn in a particular phone for x amount of hours. This is coming from guys that make the phones. You would figure they would know if burn in actually has an effect or not.
Anyways what I do is I have a dedicated laptop fllled with music. colored noise works but I actually have a particular type of music I use.
I use a drum n bass album I bought a long time ago. It is about 5 hours of non stop drum n bass. I leave this album on mix and let it rip. Fast drum beats the poo out of drivers. I leave volume in medium- loudish. Not blasting but for dynamics it is ok to have a bit of a volume the idea is to work out the drivers.
This works too http://www.bassdrive.com/ Leave it on this station. pump up the volume till you feel it is at a good volume right before you feel it is loud. cover a jacket over the headphone. Let it rip.
I have burned in every single one of my headphones and earphones this way. Works fantastic. The only exception is earphones with BAs in them. I just use regular music and lower volumes.
