Thank you everyone for the suggestions! Oddly enough I was able to get through a few hours for the first time with no issues! I am going to try and take them carefully apart and see if something is loose. I am reaching out to Focal today to see what they say just in case they fail again.
Man, I Love these headphones! I have been using this for several days with my tube amp and the sound is Great.
Today I got my Liquid Platinum amp and I am most curious to see how the Elex's work out with this.
It might be interesting. The tube hybrid may soften the upper-mids dyanmics a bit, which I found too forward with slight reduction in mids weight, causing the upper-mids forwardness to be sharper than preferred and cause detachment from being engaged to the music. I know LP thickens up the mids too.
For the last week I have been down to two amps and I have been A-B'ing with my tube amp (MAD Ear+ HD II) and a THX amp (SMSL SP200). Wildly different sounds. That tube is smooth, but SP200 is banging out that great bass.
Very curious to see where the LP fits in.
Elex + THX AAA 789 is a very fast, controlled ride. Also very lean sounding. I like to use a warm opamp in the preamp before feeding to the 789 to flesh out the Elex's midrange. A tube amp would work too but then it loses that precision from the fantastic 789!
Me too, since I currently use the THX 789 with the Elex (Valhalla 2 with the Sennheiser HD 6XX) and expect to buy a Liquid Platinum in 2-3 months. I'm planning to use my stimulus money (which should arrive within a week) to buy a ZMF Aeolus, which may well supplant the Elex as my primary music headphone. I'm guessing that the LP will pair better with the Aeolus than the 789 (and given the likely backlog of orders at ZMF, I'll bet I get the LP before I receive the Aeolus).
I don't have a 789, but I do have an SP200. Sounds good with Elex with good music, but can be a little fussy. Strong bass though.
Got my LP yesterday and it is wild! Tried several genres and it sailed through everything. Full, detailed sound with lots of bass. Although it is way too early to say this, I can see this replacing my SP200.
I just put on my Sundara's and I will see where that goes. Awesome to start. Played some lush Mercury Rev (Bobbie Gentry album) and then switched over to STP playlist on shuffle. VERY nice.
Frankly, after having three OEM Elex XLR cables fail in a little more than a year (carefully used, never left my apartment; I now use one from Periapt) I wouldn't ever consider buying a Focal product again.
