Jimster480
Many have found inconsistencies before.I know what VA stands for - volt x amps = watts. But the label says 14VAC which is the RMS voltage rating of the wall wart. This is the voltage spec of the transformer, separate from the wattage rating of the transformer.
The 24VA rating of transformer says it can driver 24watts.
If the amp internally has +/-17v dual rail supply, I find it interesting how that can be achieved with a single output 14VAC transformer? Unless a voltage doubler is used. In any case - If specs say +/-17v dual rail (34v full swing) internally then 1.3W is possible.
Just curious how one gets 34v swing from nominal 19v swing transformer. Not impossible just requires either a DC step up or a doubler or dual output secondaries (not the case as jack is standard 2 pin 5.5mm barrel type).
Schiit won't come out to talk about them.
Only make random comments about things which don't make sense and refer to other threads where they will not answer the same questions.
