MatthijsD
I’m not sure If my question fits in this thread. If not, please say so. Do you think this amp would make a good combination with the AKG K-712 pro?
Not sure if I can help as much as you need, I haven't heard the AKGs, but in my experience with the four headphones I have here, the Magni 3 is so neutral that it expresses the exact frequency balance of each of the headphones, from 22 ohms to 600 ohms, yes, it actually drives my 600 ohm Senn HD540Rs! Each headphone balance being totally different and being familiar with all of them over some years, I can say quite definitively they all sound like themselves. Bright and lacking in bass fullness will sound exactly like that ... and so on, right down to the modified Denon AH-D1000s, thicker in the bass, warm, lacking in really fine detail yet all of them are great fun.I’m not sure If my question fits in this thread. If not, please say so. Do you think this amp would make a good combination with the AKG K-712 pro?
Addictive is a good word! Sounds great even directly out from my Marantz DV6600 SACD/CD/DVD player and even with just Redbook CD. TajMo's new album sounds full of life and accurate enough to almost be a clone of the balance from the QP1R DAP, just a bigger sound, which is good news for me and shows the accuracy of the Magni 3. Loving it more each day.It sounds amazing with my AKG Q701 which has the same impedance and sensitivity specs. It drives it easily on the low gain setting. I really think Schiit has a huge winner on their hand with the Magni 3. They really did not make a big deal about it when it launched but I honestly don't think there has ever been any amp that sounds this good at $99. It holds its own against all the amps I have ever tried, including the original Vali, the Vali 2 ($149), the Valhalla 2 ($349), and Bottlehead Crack with Speedball ($414+labor). The reason why I got the Magni 3 is because I needed a solid state amp that could drive planars and that would give me a low noise floor with maximum RFI protection. I live very close to an airport and have often been able to pick up all kinds of radar pings and clicks especially with the Crack in combination with certain tubes. What I did not expect is to get an amp that is so addictive sounding that I have not even turned on my Valhalla 2 in a week. Like I said before, the Magni 3 really capitalizes on everything that solid state amps are good at - speed, slam and a very low noise floor. It manages to avoid the traditional pitfalls of entry-level solid state amps - it is not too bright, it does not sound compressed, and does not have a narrow soundstage. Honestly, the fact that a headphone enthusiast can now get the Magni 3, the Vali 2, and Modi Multibit for under $500 is kind of incredible. I paid more than that for only my Bifrost Multibit less than 2 years ago!
Possibly quite an improvement! Such a high output impedance with the Onkyo comes via two resistors tapped off the output stages of the power amp and this will alter the frequency balance of some headphones, some significantly and others only a little.Thank you for your input in helping me in answering my question:
May I ask you an additional question. At the moment the AKG is connected to an Onkyo TX-8150 ( Headphone Output Impedance 390. Ω Headphone Rated Output 200 mW (32 Ω, 1 kHz, 10%))
Do you think the Magni 3 will be an improvement compared to the Onkyo? People say the AKG like a lot of current.
Sorry if this question is too simple but I have just discovered the world of headphones and am not technical at all.
Now that IS something I can't tell you It does give you a chance to play around with valves/tubes though. I almost bought the Vali 2, then decided on the Magni 3 instead - I can use the Valhalla 2 for playing with tubes. Still, in this world that has an excess of really expensive gear that isn't always as good as the price might suggest, $150 is a bargain ... unless you're a poor student - to upgrade to yet another great amp from Schiit Audio!I am so excited to consult you guys,that is it worth paying $150 extra for Asgard 2,given that Magni 3 is great at price $99?
I don't have my own Mimby yet (next on my list), but from all the other stories I've heard here and from Schiit themselves, the M3 will bring smoother and more balanced sound and I CAN tell you that the M3 is very clean and detailed in the top end while being very even.Hi, I currently have the Modi2U+Magni2U with HD600 headphone and loving it
I’ve been thinking of getting the Modi Multibit for a while now and with the Magni3 coming it’s even more interesting!
What would be the sonic difference of the MM+M3 over the uber stack?
...Honestly, the fact that a headphone enthusiast can now get the Magni 3, the Vali 2, and Modi Multibit for under $500 is kind of incredible. I paid more than that for only my Bifrost Multibit less than 2 years ago!
I have the mmm3 stack currently and had the mu2 stack for ages so I know it quite well. Will use hd650 as reference as I don't have the 600.Hi, I currently have the Modi2U+Magni2U with HD600 headphone and loving it
