Zbell
Just got my Magni 3 today and gave it a couple hours to warm up. I'm upgrading from a Magni 2U (mostly because I need something for work), so I was able to compare them for about an hour tonight. Before getting into the sound, I think the feel of the Magni 3's volume knob is much smoother than the 2U. Honestly I didn't think I would really care about the feel of the knob, but it's a plus for sure.
For reference, I was playing mostly Other Voices, by LCD Soundsystem and tested the amps using Senn HD600 and Fostex TH-X00 PH. My initial impression was that the depth of the soundstage sounded a little different and I found the Magni 3 to be bit more open/airy, and maybe a little more delicate (which I'm not sure how I feel about). The second thing I noticed was that the bass was little sharper and less bloated on the Magni 3, especially when using the Fostex. I can hear the strumming of the bass in the beginning of the song with a little more texture using the Magni 3. The last thing I listened for was how bright the highs were. Using this track around the 4:30 mark, I find the Magni 3 to definitely be a bit less strident when using the HD600s. Take all this with a grain of salt as these were my initial impressions after only an hour and change of listening. It was also not a blind test, as I had the switch the RCA cables back and forth and I never discount the power of confirmation bias.
My final take is that this is a great buy for $99, especially considering I paid $149 for the 2U. I'll try to update in the next few days after comparing them more thoroughly.
