Magni 3 Impressions
Apr 22, 2019 at 6:34 PM Post #2,431 of 2,593
Would a magni 3 be able to power a LCD X or LCD 2 decently ?
Audeze states a recommended power input of 250 mW, and they have a maximum of 5W for the LCD X. At 20-Ohms you will be between a maximum output power of 2,500 mW and 3,000 mW. I'm sure the continuous power is going to be well over 250 mW at maximum listening levels.
Apr 22, 2019 at 6:39 PM Post #2,432 of 2,593
They say that the LCD X is 20-Ohms and needs >250 milliwatts.
LCD 2 - Impedance 70 ohms and needs >250 milliwatts, also
Magni 3 puts out:
Maximum Power, 16 ohms: 3W RMS per channel
Maximum Power, 32 ohms: 2W RMS per channel
so it should have plenty to offer
Apr 22, 2019 at 6:42 PM Post #2,433 of 2,593
Magni 3 puts out:
Cool thanks, appreciate the help
May 19, 2019 at 2:06 PM Post #2,435 of 2,593
I have an objective 2 amp and a Schiit magni 3. In order to match volume levels between the two amps , I have to turn the magni up 2 to 3 notches on the volume knob.
If I have the o2 on11:00 o'clock, I have to turn up the magni3 to 2:00 o'clock to get the same volume level.
Does anyone know why this is?
May 19, 2019 at 3:26 PM Post #2,436 of 2,593
The Magni 3 was designed so that easy to drive headphones would have sufficient range on the volume knob, in order to avoid channel imbalance because you can't turn the volume up past 8 o'clock. This was a complaint with previous Schiit amps, that you couldn't avoid channel imbalance because it became too loud past 8 o'clock.
Of course, now we have complaints of the opposite nature. You can't win. :ksc75smile:
FWIW, I am a low volume listener and generally have the Magni 3 at 11 o'clock with Senn HD650.
May 19, 2019 at 6:39 PM Post #2,437 of 2,593
Thanks for the response. I suppose that could explain it..
I was using the hd6xx at low gain with the volume at about 2:30. With high gain I set it at 12:00 o'clock.
With the objective 2 the same volume level is achieved 2 to 3 notches lower, in either high gain or low gain.
It's not a big deal. It still sounds good. And the hd6xx is the hardest to drive of all my headphones.
May 20, 2019 at 9:30 AM Post #2,438 of 2,593
I usually keep it at 9:30 (low gain) for HD6XX.
Not a terribly big difference to the 9 o’clock I used to have on the Magni2U - but that probably is I part because of the Modi Multibit I use with the Magni3 having a higher output level.
Interestingly, despite having tons of more power, I have my Lyr3 multibit also at 9 o’clock (high gain) :)
May 20, 2019 at 10:34 PM Post #2,439 of 2,593
I wonder if the output voltage on the source has something to do with it.
Maybe my objective 2 doesn't need as high an input voltage as the magni 3. Sort of like how different headphones have different sensitivity ratings.
I don't know enough about electronics to know what input impedance ratings mean for power amps; but the objective 2 apparently has an imput impedance rating of 10 kohms. The magni 3 has an input impedance rating of 25 kohms.
May 27, 2019 at 11:11 AM Post #2,440 of 2,593
Why Magni 3, with power consumption of only 6w, is more powerful than Asgard 2, with power consumption of 30w?!
The Magni is a push pull amplifier which is more efficient plus they sound better than a class A in my opinion. Class AB amplifiers have a better rhythm and pace and get you moving. Class A amplifiers are biased very high and get very hot due to the transistor doing both the positive and negative part of the sign-wave. This is wasted energy and requires a lot of current to keep the transistors running. This is why the Asgard 2 has a 30 watt draw.
May 28, 2019 at 12:36 AM Post #2,441 of 2,593
I just got a magni 3. It's my first headphone amp. At low volumes (up to a little less than 9 o clock) sound only comes out of my left headphone cup. Soon after that sound starts coming out of the right cup as well, and by 11 o clock I think the volume coming out of both channels is the same, but I can't be sure.
Is this normal?
May 28, 2019 at 1:47 AM Post #2,442 of 2,593
Just got my yesterday and it's also my first headphone amp. I just tried it and with my unit it's only the right channel playing at very low volume, but I'd never use it that low so it's ok for me. But I expected a bit more power from it reading from everyone about it. I use it at low gain at 75% for music
May 28, 2019 at 2:03 AM Post #2,443 of 2,593
To drive my hd6xx to 80db-85db , I run my magni3 at 75%; which is fine. If I want to run it on high gain, I set it to 50%.It's not a problem, for me.
May 28, 2019 at 12:18 PM Post #2,444 of 2,593
It all depends on your source, and what headphones you are using. What is your equipment list?
