BrotherKathos
Hi, I have a Fiio X5iii and a Sennheiser HD 598. I only have had 598 and I don't use in ears.
I am looking for a sound quality that is more neutral. I have options for 2 amps. I can buy either Fiio A5 or Magni 3. Portability or not is not an issue. Only sound quality matters. Can anyone here who has experienced both recommend a better amplifier?
If you want neutral then magni 3 is off the list There is a great option you might not be aware of instead. Its the JDS labs Atom. Its $99 and has all the same features as the magni 3 while using the same output stage as jds labs flagship element amp which i own and like much more than the magni 3. The atom is designed to be a next generation o2 amp so neutrality and transparent amping is its mission first and formost. I’ve found the el amp to be very neutral and smooth comapared to the magni 3. Hope this helps
https://www.jdslabs.com/mobile/products/190/atom-amp/
