"Mad Dog" by MrSpeakers, modified Fostex T50RP review
Sep 12, 2012 at 2:24 AM Post #1,036 of 6,388
Also, don't forget the Asgard amp, runs in class "A" mode and the case is the heat sink for the amp itself.  So don't be surprised at the level of heat that may be produced.
Way ahead of you, I already do eggs and bacon on it in the morning after it warms up.
Sep 12, 2012 at 9:25 AM Post #1,039 of 6,388
Yes, that's the case. I'd call it semi soft. There is some foam inside. It's not a Pelican case but It'll do.
gL!!
Matt,
If that's the same case I got with my T70's then I would not use that.  It has lots of foam around all sides but it has none at the top where the
[size=1.33em] Beyerdynamic name is[/size]
Sep 12, 2012 at 10:00 AM Post #1,041 of 6,388
*****Dog Pads as Promised*****
Jealous...How was the install?  Pretty straight forward?
Sep 12, 2012 at 10:33 AM Post #1,043 of 6,388
Dan did it.
Yeah, I realized after I posted that you probably got one of the premade ones.  Post impressions when you get a chance.  Excited to hear about the changes.
Sep 12, 2012 at 11:18 AM Post #1,044 of 6,388
Matt,
I don't think the T50Rps would need as much protection... I think that the Beyerdynamic case would be overkill for it. (I use that very same case with extra padding on the top for my D5000s... (woodies..)
Sep 12, 2012 at 3:59 PM Post #1,048 of 6,388
Okay, I've done some looking, and I cannot for the LIFE of me find where to order these. Do I just message mrspeakers or something?
Also, I've read this works well with the E11, is that right?
Sep 12, 2012 at 5:17 PM Post #1,050 of 6,388
Well according to this: http://grooveshark.com/#!/s/The+Ferryman/3C8SBc?src=5 it outputs 200 mw at 32 olms, so at 50 olms which this headphone is, it's like 140 olms. However the sight reccomends you get an amp that outputs 100 mW per channel. The e11 has 3 channels and140 over 3 is less then 50 mW per channel which isn't near enough to drive it properly.
